crack on foward cross support on frame
Old Jan 10, 2000 | 08:54 PM
JEFF 81 RANGER's Avatar
Unhappy crack on foward cross support on frame
I have a 81 ranger f150 4x4 with a lift kit
there is a crack on the foward cross support
on the left side near the steering box.It has
been repaired once by a prior owner,a plate
was welded over the crack which cracked where
the existing crack was.Has any body had or
heard of this problem and any sugestions on
a fix.
Old Jan 10, 2000 | 10:56 PM
XLTJAKE's Avatar
Post
Lift kits and steering linkage mods are notorious for putting extra strain on your steering box, causing frame flexing and, ultimately cracking. I don't know about your particular application, but I would have a good spring or front end shop take a look at it to determine the cause of the excess stress. If you just weld the frame and don't fix the source of the problem, it will recur.
BLK 2000 F150 XLT 4X4 SuperCab SB, Shift-on-the-fly, 5.4L, 4R70W, 3.55 LS, 4-Wheel disc/ABS, ORP, Keyless, PWR Seat, Slider, Soft tonneau, Cab steps.
MODS: Rhino, Molded flaps
