two speed
Old Jan 7, 2000 | 07:33 PM
insect2's Avatar
Talking two speed
Way way back when - we had a pick up that had a small flip lever on the floor gear shift ****. When you flip this lever up or down it would change the rear end to a different gear. This pick up had a two speed rear end. It was so great for towing heavy loads when in the low range. This truck had a three speed trans, and with the two speed rear end had six gears selections.
Does anyone know if anyone sells an aftermarked two speed rear end like this that I could purchase. I did see advertised somewhere a six speed transmission for F-150 that gave a super low gear for towing but I dont remember who had it.
Any answers.
Old Jan 7, 2000 | 07:56 PM
StrangeRanger's Avatar
Post
Try Gear Vendors. Don't know if they've got a web site, but thet make 2 speed tailshaft units for auto trannys.
Old Jan 7, 2000 | 07:59 PM
insect2's Avatar
Post
StrangeRanger - Thanks for the reply.
Will these work for a standard 5-speed?
Old Jan 7, 2000 | 09:14 PM
manx's Avatar
Post
some of the bigger trucks (f650)
come with split axles
it's common
99 XLT SC 4x4 STYLESIDE ORP 5.4,AUTO & 3.73 POSI
MED. TOREADOR RED
EXTANG TONEAU,BED MAT,
K&N FILTER & WOOD DASH KIT
Old Jan 7, 2000 | 11:36 PM
Post
Insect2-
here's the URL http://www.gearvendors.com/
see if they can tell you what you need to know
Old Jan 8, 2000 | 10:41 AM
T Ellenberger's Avatar
Post
My friend with the F-250LD 5.4 has the gear vendor and had the rear end changed to 4.10 also. He also installed BF Goodrich 245/75/16s which are a little taller than stock. He can cruise with no load at less rpm than I can. He uses a pedal on the floor like the old headlight dimmers to turn the gear vendor on and off. When he pulls his 27 foot travel trailer he uses the gear vendor. I have no idea about costs because he had the gear vendor from an old truck and the shop just added a new piece to mount to his F-250LD. He also had a new drive shaft made.
97 F-150, 2WD, Reg Cab,Flareside,Dk Toreador Red, 4.6, 3.55 LS, EGR Bug Deflector, ******* Bed Cover, Bed Liner, XL Full Length Running Boards, Air Aid Kit, Gibson Single Out Cat Back, Superchips, TransGo Shift Kit, Hellwig Rear Sway Bar, Hellwig 2500# Overload Springs
Old Jan 8, 2000 | 10:31 PM
jgorka's Avatar
Post
The electric two-speed axle to which you referred http://truck.eaton.com/na/spec_produ...speed_axle.htm are still available -- but on slightly larger trucks.
High-torque electronicly-controlled engines and 6-speed transmissions (known as 6+1) have replaced most 5-speed trannies with two-speed axles (known as 5+2).
You can find 'underdrive' gearboxes for insertion between your transmission and rear axle -- but they too are expensive.
I had hoped for years that a market for two-speed axle would develop -- so I could pop one under my (then) diesel Suburban, but there is really no market for them (think about it -- who needs lots of reduction AND highway speeds? Perhaps a farmer -- but they can live with what's available now. "Granny" gear and .7OD with a 4.56 will do it for most of those applications.
Edited to make the link work.
Y2K XLT EC 5.4L 7700# SB 4x4 w/LS 3.73 (repeat buyer)
[This message has been edited by jgorka (edited 01-08-2000).]
