4X4 Does not engage
Old Feb 23, 2003 | 05:38 PM
Bigazford's Avatar
Question 4X4 Does not engage
I have a '97 F-150 supercrew. The 4X4 will not engage. I replace the electronic shifter moter and now I can hear the transfer case engaging but I still have no 4-wheel drive. Any suggestions.
Old Feb 23, 2003 | 07:53 PM
JMC's Avatar
JMC
25 Year Member
Is the 4x4 light on? Does it go into 4Lo?
It could be the front axle is not engaging.
put it in neutral with the parking brake engaged and try to turn the front drive shaft. It should not turn.
JMC
Old Feb 23, 2003 | 09:25 PM
Bigazford's Avatar
Yes the light does come on and no it will not go into 4lo either. I will try to do the parking brake trick and see if that gets me any ideas. Thank you!
Old Feb 24, 2003 | 01:21 AM
JMC's Avatar
JMC
25 Year Member
Drive the truck with it in 4 low to determine if the T-case shifted into 4Lo. If it feels like it went into Lo try the drive shaft trick. It may well be that the front axle is not engaging.
JMC
Old Feb 25, 2003 | 08:52 PM
6Jeff6's Avatar
My money is on the actuator on top of the front axle. I have a 1997 F-150 and that's what my problem is. The transfer goes into 4wd but no power is ever put to the front axle.
2 97 F-150's
one modded
one not
