How much does it weigh?
Old Dec 28, 2007 | 07:32 AM
kaboom10's Avatar
I have a 2002 F-150 5.4 L 4wd extended cab. How much does it weigh unloaded? obtw it's stock.
Old Dec 29, 2007 | 02:49 PM
2005lariatky's Avatar
Look on the drivers side door sticker.
Old Dec 29, 2007 | 03:22 PM
kaboom10's Avatar
Thanx. I looked online and it said 4550 but I'll ck.
Old Dec 29, 2007 | 05:48 PM
kaboom10's Avatar
The sticker reads 1632kg which equates to 3590lbs. Why did it say 4550 online?
Old Dec 29, 2007 | 10:24 PM
That is a good question. Most cars weigh more than 3500lbs. Is yours a ext cab, crew cab, short or long bed?
Old Dec 29, 2007 | 10:49 PM
kaboom10's Avatar
It's an extended cab model. It also has a gross vehicle weight for front and rear that says 3600lbs.
Old Dec 30, 2007 | 01:42 AM
The door sticker doesn't list curb weight to the best of my knowledge. Your owner's manual will list curb weight. If you don't have one, you can download it in pdf format.
http://www.fleet.ford.com/maintenanc...ls/default.asp
Old Dec 30, 2007 | 10:29 AM
kaboom10's Avatar
Thanx for the info but it reads to take the vehicle to a commercial weigh station. I need the figure to plug into a math formula for drag racing.
Old Dec 30, 2007 | 12:38 PM
Sorry about that. Here you go:
http://www.fordf150.net/specs/02f150.php
Somewhere between 4600 and 5000, depending on bed and GVW package.
Old Dec 30, 2007 | 06:37 PM
kaboom10's Avatar
I wish I could find the window sticker to see exactly what I have. I'll probably go to a weigh scale.
Old Dec 31, 2007 | 12:44 AM
You can get the GVWR off the door jamb sticker. That should be all you need, the other variables are obvious. 138.5 is short (6.5 foot?) bed, 157.4 is long (8 foot) bed. Flareside is the narrow bed with bulging fenders like Chevy's Stepside.
Old Dec 31, 2007 | 07:07 AM
kaboom10's Avatar
That narrows it down quick. 4942 is the only weight listed. Thanx again.
