wire harnesses
Old Dec 7, 1999 | 03:02 PM
pat's Avatar
pat
Question wire harnesses
loooking up the right & left front fenders behind the head lights on my 99 lariat,i'm seeing two vacant wire harnesses,are these for fog lights?i have the auto lamp system.if these wires are for uninstalled fog lights where do they go,for a switch? thanks,pat
Old Dec 7, 1999 | 08:02 PM
Sycoholic's Avatar
Cool
I do believe they are for the fog lights, although I don' know if the switch you have will work, never tried it, never had a reason to. If I can I'll look into it tomorrow.
1997 F-150, 4.6, automatic, Dark Toreador Red, Supercab, Flareside, 4X4 Off-Road, Towing Package, Chrome Grizzly Wrap Around Push Bar, Ford bedliner, Code Alarm Sure Start RVS remote starter, Realistic CB with Wilson Little Wil antenna and Astatic power mic, ported MAF sensor, and Lots of TLC!! (Besides being an F-150 nut, I am a Ford auto technician.)
Old Dec 7, 1999 | 08:15 PM
Freezer's Avatar
Post
pat, I think they do goto the fog lamps. This summer I got a kit from Ford to add fog lamps to my truck (because I have a 4x2). When I was replacing the switch inside the cabin, I noticed it was already "wired" for fog lamps, according to the instructions. But by that time it was too late for me to test those connectors. What you should do it just hook a volt meter to them and then pull the lever and see if you get juice.
1999 Lariat SuperCab Flareside, Amazon Green with Silver trim, 5.4L, 4x2, 4 wheel disc/ABS, 3.55 limited slip, towing package, fog lamps, sliding rear window, captains chairs, keyless entry with alarm, spray-on bed liner, bug guard, and K&N. http://www.csc.calpoly.edu/~bfriesen/truck.html
