Body Leans
yep, I used to have the same problem with my truck. Dealer said it was 'within limits'. Something like 1.5 inches is limit. I greatly reduced the lean by putting the truck on a lift (pads on the frame) and letting the suspension hang for a while while I did an oilchange and tire rotation. After that the lean was mostly gone.
Fritz
Fritz
I had that happen to a car I owned a while back. I replaced the coil springs and shocks to correct the problem.
During the installation I discovered that the lower side had a blown out shock absorber. The worn out shock absorber apparently caused that one coil spring to sag more than the one with the good shock. Go figure.
