joining the bed and the cab, is it possible?
Old Sep 23, 2001 | 05:43 PM
nemesis347's Avatar
Question joining the bed and the cab, is it possible?
I was wondering if it is possible to cut out the back of a pickup's cab, so that if there is a cap on the bed of the truck that it would all be connected, like an suv. I have seen blow thru designs in pickups so that sub woofers can fire into the cab and have the box in the bed. i would like to connect the bed and cab of a reg cab F-350, so that i could put a seat in the bed and it would be like a large bronco with a diesel. any help would be appreciated.
Old Sep 23, 2001 | 06:08 PM
Robdude30's Avatar
Post
I had an '86 Toyota 4WD that I cut out a portion of the back of the cab and bed and joined them with rubber material similar to that camper top boot rubber that goes around the windows. I didn't cut the steel all the way to the outside so you couldn't see it from the outside unless you looked inbetween the cab/bed gap. It looked pretty good and functioned well. I was told at the time that if I were to weld the cab and bed together that there could be enough flex at times between the cab and bed to break it back apart.
Just my .02
Old Sep 24, 2001 | 11:45 AM
Jimmy Lee's Avatar
Why not just buy an Excursion
JJ
