2003 gas tank
Old Aug 8, 2015 | 01:53 PM
BigBuckMafia's Avatar
2003 gas tank
Okay so I see they make a 24.5 and a 30 gallon gas tank for my 2003 Ford F-150. I have the 24.5 gallon one on it. But it rotted out so I need a new one but for $10 more I can get the 30 gallon one. Will the fuel pump/gauge work in it ? Will the straps mount in the same spot ? And will it fit under the truck ? It's a reg. cab short bed. Thanks !
Old Aug 12, 2015 | 04:15 AM
AlfredB18's Avatar
I'd imagine the 30 gallon version is for long beds. How much of a challenge are you up for? You would probably be re-engineering strap mounts, for starters. As you can see from the links below, the 30-gallon version is nine inches longer. Get your ruler out and see if you have enough room underneath.
http://www.ebay.com/itm/30-Gallon-Gas-Fuel-Tank-for-1997-1998-Ford-F-250-150-/310351689613?fits=Model%3AF-150
http://www.ebay.com/itm/24-5-Gallon-...-/131287186969
Old Aug 12, 2015 | 02:46 PM
I believe they have different pumps/connector as well
Old Aug 12, 2015 | 03:31 PM
Correct. Short beds are 24.5 on 4wd and 25 on 2wd.
Old Aug 17, 2015 | 10:52 PM
Sorry for the late reply. I just went and bought the 24.5 gallon one
