need help with paint code
Old Aug 20, 2014 | 06:52 PM
Jmax 857's Avatar
Size:  111.4 KBName:  20140810_171055.jpg
my truck is a 2 tone f150, 2001.
Black on top silver on the bottom, my door tag only shows the code for the black, and I need a code for the silver to do some re-painti ng
Old Sep 15, 2018 | 01:21 PM
Arleen Young's Avatar
Bottom silver color!
Sounds like to me the silver was added on later. Unless you've had that truck a long time! Bcuz both of the codes will b inside the door jam. You need to take it to your nearest paint supply store and let someone help u match that silver up. I use to work in the automotive paint service . with a PPG store and back then when i worked which has been a long time now. They had gotten what was called the code reader machine. A small hand held gadget that all you did was place it on the color needing to be matched a few different times to see if it read the same each time and yhen when it had a match we'd take back into the store , hook it up to the computer and it would print out a label for that color. Or if your lucky you can be near a paint store that has a manager like i had that knew how to do everything ! Ecspecially color matching and tinting. But those are my suggestions for your silver color!
Old Sep 15, 2018 | 02:48 PM
MKTRUCK's Avatar
25 Year Member
http://www.autocolorlibrary.com/aclc...-Ford-pg01.jpg
Edit: I forgot my story. It looks like page 9 shows the lower accents. YN is silver.
MK
Old Sep 15, 2018 | 02:55 PM
Nope, that's factory. My son in law has a 98 with silver under red.
