Tow hooks on a 2wd
Tow hooks on a 2wd
im replacing my front valance on my 2wd screw after nailing a ditch and was thinking, i really want some tow hooks. Does anyone have any ides of how i could mount them. and another thing, with the 4wd front valance, how could i wire up the fogs?
if you stick with the 2wd valance you will have to cut the lower bumper to get them to fit
you will also have to probably have to drill holes to mount them also
if you use a 4wd bumper you wont have to cut for the tow hooks but you might still need to drill holes in the frame
for the fog lights if you have the wiring for them you can use the stock wiring but that will require some work to make them work
or you can get someone on here to make you a wiring diagram to hook up the lights to a separate switch
hope that helps
hope that helps
