Body Lift Problem
Old Feb 20, 2004 | 04:09 PM
jry3's Avatar
Body Lift Problem
I JUST INSTALLED A BODY LIFT ON A 1994 F-150 FLARESIDE AND NOW THE DOOR ON THE DRIVER SIDE HITS THE FENDER WHEN IT OPENS AND CLOSES, I AM NOT SURE WHAT TO DO THE INSTALL WENT FINE, ALSO HOW DO YOU PUT THE BUMPER IN THE NEW POSITION, WAS TOLD YOU MAY HAVE TO CUT THE FRAME A LITTLE TO FIT THE BUMPER ON, I AM WILLING TO DO SO BUT I WANTED TO MAKE SURE THAT IS THE CORRECT WAY TO DO SO I DONT MESS ANYTHING UP.
Old Feb 21, 2004 | 05:40 PM
brahmus's Avatar
you do have to cut the frame rails alittle to fit the bumper and the reason you are hitting the fender is because when you lifted the front of the truck the body shifted. stand behind the truck and see if you can verify this. if so loosen the two bolts near the radiator that holds the front to the frame and try and shift it back over. the front of the older fords aren't as rigid and tend to shift like that.
Old Feb 23, 2004 | 09:08 AM
jry3's Avatar
I FIXED THE DOOR IT SHUTS FINE NOW AND I CUT THE FRAME BUT JUST CANNOT GET THE BUMBER TO STAY ON THERE NICE ( THE WAY I WANT IT KEEPS SAGGING ON THE CORNERS, I AM CONSIDERING TAKING IT TO A BODY SHOP TO GET IT FIXED, ALSO DOES ANYONE KNOW A GOOD PLACE TO GET SOME TOUCH PAINT THATS EASY TO USE, I HAVE A FEW SCRATCHES FROM THE LIFT.
Old Feb 24, 2004 | 11:53 AM
UrbanCowboy's Avatar
I took a different appraoch when lifting my 95. I cut a couple notches out of my bumper and let the frame poke through. Filled the hole in the frame with expanding foam from a can and spray painted it. It's hidden a bit by my grillguard. I do funny things like that.
The bumper is real tricky; especially if you have bent mounting brackets like I did. You just have to torque those bolts down real real tight.
