My amp keeps blowing the fuse on my power wire?
Old Apr 7, 2002 | 08:17 PM
harleyvette's Avatar
Everytime I stick a new fuse in my power wire, it automatically blows. I have all the wires hooked correctly, power, ground, and remote. My thought is that it is not grounded properly. ANy suggestions. THanks
Old Apr 7, 2002 | 08:46 PM
Clem's Avatar
An improper ground won't blow the fuse. You most likely have your power wire grounding on metal somewhere or an internal problem in your amp. You might try running a separate (temporary) power wire to the battery to bypass the existing one. That way you could rule out that possibility. I've fried amps before which repeatedly blew fuses until I figured out what was wrong. Hopefully it's just a pinched power wire.
Keep us posted.
Clem
Old Apr 8, 2002 | 08:39 AM
J-150's Avatar
awww just cram some aluminum foil in the fuse holder.
Old Apr 8, 2002 | 08:56 AM
Clem's Avatar
.........or that.
Old Apr 12, 2002 | 08:43 AM
Kompressor's Avatar
Exclamation
Make sure you are using the correct fuse. It should be rated for about 10 amps more than your amplifier can pull.
watts/volts=amps
