Headliner
Has anyone removed their headliner and put Dynamat up there? Is it worth it? Or even better, has anyone laid it down everywhere inside their SCab? Did it make a big difference and how much did it take? I was looking to pick up two 36' rolls of Xtreme and if it only took one I would just return the other one. But if really only makes a difference to do the doors I won't worry about the rest of it. Thanks.
Doing the top of the interior would cut down on windnoise. I recommend raammat over just about anything. Its around a buck a foot and is equal to dynamat extreme. It will make a huge difference in interior noise and rattles if you lay down enough.
Deus, have you put it up there in an f-150? I'm just wondering how hard it is to take down (like is it glued anywhere) before I try to remove it. The doors and floor should be pretty straightforward. Also, I couldn't find anything on the internet referring to raammat. Where could I go to get info on that? Thanks.
Charles
Charles
