CD Player Problem
Old Jan 18, 2002 | 10:00 AM
whatdayathink's Avatar
CD Player Problem
I have a factory Ford radio and CD Player. My CD Player all of a sudden quit working. No power, no nothing. The radio says "NO CD". It will not even eject. (OK..I think you get the picture)
The dealer told me I need to get a new wire harness that it has most likely gone bad.
I was going to remove the radio (when I get the stupid tool). My hope is that the plug is just loose, but I am sure it is more than that. My next step would be to check each wire in the harness.
My questions is - what has been the past experience with this problem? Is this a common problem for the wire harness to go out?
Does anyone have the wire/color guide for the harness? I would like to at least check to see if the player is getting power to try to narrow things down.
Thanks!
Old Jan 18, 2002 | 10:52 AM
Norm's Avatar
This is an indash cd right? If so you should get a replacement from Ford, it is not detecting a disc. The harness only applies to the external changer. If you have the changer and the harness is bad it say "NO DJ" or something similar. If you have a changer and the cartridge is jammed or empty you would get "NO CD"
Old Jan 21, 2002 | 12:46 PM
My Bad - left out that important detail. Yes, it is the external Cd Player.
