Aswc question
Old Dec 25, 2012 | 07:21 PM
chavez1975's Avatar
Aswc question
I'm about to install the FH X700BT to my 2010 SCREW and I'm a bit confused on the right wire to use on the ASWC harness. The website says I only need to use White/green? is that all. If so, what pin/cikir do I hook it up into the ford wire harness? I hope this makes sense..
Old Dec 31, 2012 | 12:34 PM
oblivion's Avatar
What deck are you using? Do you have the standard stereo or the Sony upgraded one?
Red, black, white/green, pin 19 to ground and the 3.5mm plug thats it.
Old Jan 19, 2013 | 07:41 PM
dixie_boysles's Avatar
When it says pin 19 to ground, does that mean you splice a ground to that wire? Or what?
Old Mar 10, 2013 | 04:05 AM
Low_e_Red's Avatar
This is fairly easy. Take Pin 19 and ground it. Splice it, put a ring terminal, etc and ground it. Take pin 20 and hook it up to White/Green. ASWC will auto program from there.
