Antenna ground.
Old Apr 10, 2011 | 05:57 PM
russo2's Avatar
Antenna ground.
I have no idea how to ground a cb antenna properly. It never mattered with my cheap uniden, but my galaxy dx 88 HL will soon be fixed and it puts out... a lot.
I'm making mirror mounts for the old swing away style mirrors and I'm using either 4' firesticks on springs or 5' steel whips from radioshack http://www.radioshack.com/product/in...ductId=2102661
I know the firesticks will be just far enough apart to work pretty good, not sure about the steel whips, may only hook one up and use the other for looks.
My biggest concern is how to properly ground either of these antenna.
Any help is appreciated.
Old Apr 10, 2011 | 10:15 PM
atr04screw's Avatar
On mine I just ran a wire from one of the bolts on the antenna mount to a bolt on the frame and it worked just fine.
Old Apr 10, 2011 | 10:29 PM
russo2's Avatar
So if the antenna is mounted on the body of the truck it is already grounded?
Or is a better ground necessary.
Old Apr 11, 2011 | 08:53 PM
atr04screw's Avatar
It should be grounded if its attatched to the body, but you might get better reception with a ground to the frame.
Old Apr 11, 2011 | 10:29 PM
fordordie1's Avatar
got mine bolted 2 da body...no probs yet
Old Apr 12, 2011 | 09:28 AM
dsq3973's Avatar
I took a piece of 12ga wire and an crimp on eyelet on both ends of the wire with a stainless screw/nut and mouted it to my antenna mount and then attached it to my bed with a stainless sheet metal screw. My reception/SWR was night and day after doing this also make sure you shrink tube both ends to keep moisture out of the wire.
Old May 21, 2011 | 07:37 PM
TX_FX4's Avatar
Are you running the firering?
