Need help disassembling factory stereo in F150
Old Feb 13, 2001 | 05:04 PM
Tamee818's Avatar
Unhappy Need help disassembling factory stereo in F150
I was wondering if i had to tak off my whole dash to get back there to it or is there some easier way i can get to it?Hope someone can help.
Old Feb 13, 2001 | 09:17 PM
Boss96Hog's Avatar
Post
If your trying to just get the radio out that is easy. You will notice 4 holes in the face of the radio, 2 on each side. They are there to allow the use of a DIN tool to release the clips that hold the radio in the dash. You can buy these tools at just about any stereo shop or order from Crutchfield.
Old Feb 13, 2001 | 11:37 PM
F150Sven's Avatar
Question
Assuming you are talking about a 97+ truck, you will need to pop the trim panel that surrounds the radio/temperature area off. It's held in with spring clips, so it will pop right off. Then use the tools mentioned above.
2000 F150 XLT 4X4 Off Road 5.4L Reg. Cab 3.55
Performance Enhancemets:
K&N
WMS Velocity Tube
Gibson Sweptside
Audio Enhancements:
All of the above, plus
Sony C7000X HU
Cerwin-Vega SS2502 components(Front)
Blaupunkt PCxp573s(Rear)
Radio-delay mod
Other Enhancements:
Extang Black Max Tonneau Cover
Old Mar 7, 2001 | 04:16 PM
98bluelariat's Avatar
Post
you may not even need to buy the tools from the shop...if you ask they may let you use them for a minute..thats all it takes, or even just come out and pull the stereo out of the dash for ya. I used to work in a stereo shop and we did that ...provided the trim had been removed. Saves money since you may never use them again and it takes mere secondes to actually take the radio out
Old Mar 7, 2001 | 04:42 PM
JDMnAR's Avatar
Exclamation
If you have a wire coat hanger and a pair of wire cutters, you can make your own. Just cut the two curved ends (if you can really call them that) into "U" shapes and they will work fine.
Old Mar 7, 2001 | 05:48 PM
Caliendo's Avatar
Post
I was using the coat hanger meathod and it worked ok. Saw the Dinn tool at Walmart today for $3.80 and bought it.
Remember to disconnect your ground for 2minutes prior to the radio removal - or at least thats what I've been told.
1998 XLT SuperCab w/ORP 4.6/auto/355LS
LineX
Bug DeflectorII
Husky Liners
