IPOD AUX location
Old Apr 2, 2009 | 10:47 PM
ltz400racer's Avatar
IPOD AUX location
So,i just purchased the PIE FRD04-AUX for my headunit. i have two questions,
1. it says that there is a audio level adjuster that you set for your headunit's specs, so waht do i set this to????
2. Where should i put the input at? i want it to look clean kind of like how the 07's come stock (in that little tray on the dash) but im not sure how i should go about this, any pics or or help would be great!! thanks!
-LTZ
Old Apr 2, 2009 | 11:54 PM
yetti96's Avatar
-LTZ
I installed mine and then adjusted the levels by ear before putting the trim panel back on.
I ran my iPod cord to the glove box, some run it to the center console if they have the flow-thru console.
Old Apr 15, 2009 | 08:22 PM
bjp207's Avatar
I put mine in the cig lighter panel, I had to fab up a cord, to make the jack stick through the dash, then thats a cord that I bought to go from the jack to the IPOD. heres a pic
Old Apr 15, 2009 | 11:01 PM
now thats more like it!! this is what i was wanting, some pics of some good ideas
Old Apr 16, 2009 | 12:29 PM
I have mine in the glove box. Out of sight, out of mind.
Old Apr 16, 2009 | 01:48 PM
hmm ok.. still not sure where to go with it.. Bj, how did you get the input to stay? i know you said that you had to make your own wire, but how did you do it?
Old Apr 16, 2009 | 04:57 PM
bjp207's Avatar
the ends of the cords were threaded(got them at radio shack)(2 jack ends), so i test drilled some holes in some other plastic and got the perfect sized hole drilled, soldered one side on, slid the cord through the hole, threaded the jack into the hole, then soldered on the other end, then I used an RCA to 1/8'' plug to go into my PIE. I could take some pics, but its pretty self explanatory, any other questions lemme know
Old Apr 16, 2009 | 05:23 PM
bjp207's Avatar
heres a rough diagram to explain my jibberish
Old Apr 16, 2009 | 06:08 PM
hmm sounds easy. haha good thing i know how to solder..
Old Apr 16, 2009 | 06:10 PM
bjp207's Avatar
haha yeah, its cake
