Soundproofing question
Old Jan 11, 2001 | 01:00 AM
dustin d's Avatar
Post Soundproofing question
I am starting to soundproof my truck. I am trying to do it as cheaply as possible. I ordered a ton of the high-temp mastic from mcmaster. I am spraying the inside of the doors with 3m spray on bed liner and I am using expanding foam to fill in all of the hollow panels.
My question is, when I apply the mastic (dynamat), what do I do with the thin plastic sheeting that sticks to the metal of the door? I am not sure if I am supposed to apply the mastic to the metal parts of the door only by cutting the shapes to fit, and then re-applying the plastic sheet. Or is the right way to cover the entire surface of the door and more or less replace the plastic sheet with the dynamat?
Dustin
Old Jan 11, 2001 | 05:50 PM
big_red_daddy's Avatar
Post
What you do is what you thought. The plastic is the moisture barrier. Use that as a template, take it off and be sure not to rip or tare it, lay it on the Dynamat and like I said use it as a template and cut out an exact replica, then apply the Dynamat to the metal of the door using a hair drier or heat gun and a rolling tool to work it into the grooves. If you need more help or more Dynamat I have some for sale in the classified ads for really really cheap
later
Hope this Helps
derik
2000 F-150 XLT Ext. Cab 4x2 Flairside Sport
Bright Red w/ Clearcoat
17" Cast Factory Wheels
Clears Corners
Ventshade Bugshield, tail light covers, & ventvisors
Custom Red Vinyl Interior
Dynamat "Extreme" &
"Premium" in all 4 doors
Bulldog Remote Starter w/ keyless entry
**And My Toy 1995 Harley-Davidson XLH Hugger
***Things To Come***
*Cold Air Intake
*Speed Grill
*Concept Audio CD/DVD/MP3 Player w/7" Monitor
*Concept Audio 200W AMP
*Installing My 2 JL Audio 10" Subs
*Altezza's for the Rear
*Dual Exhaust
*White Gage Faces(Indiglo)
*20" or Bigger Rims
*Ram Air Hood
*And more That I'm Forgetting Now
Old Jan 12, 2001 | 03:51 AM
dustin d's Avatar
Post
So I basically want to seal off the entire door, making sure that the dynamat bonds well to the metal? I just wanted to make sure that its ok to seal off the open parts.
Dustin
Old Jan 12, 2001 | 05:56 PM
Post
yep
