Check out my updated install!!!
Old Nov 21, 2000 | 09:28 PM
red97's Avatar
Thumbs up Check out my updated install!!!
I fanally got my install pretty much done. Check it out by clicking on the sight in my signature. 2 10's under rear seat and then some.
Red '97 F-150 SC 4x4 off-road, 16" rims instead of factory 17"'s(borrowed from old '97 reg cab), BFG 265/75 16 all terrain T/A, K&N filter with modified air box, Flowmaster 40 with duals out back, Expedition center console, 3" rear seat lift, after market stereo seen at HTTP://members.sounddomain.com/red97
Old Nov 27, 2000 | 08:52 PM
Don C's Avatar
Post
Red
Looks cool, I bet it cranks.
I like what you did with the heat/AC controls, which allowed you to put two units in the dash without ripping the inside if the dash apart.
Just one question how do the subs sound, and would you call that infanatly baffled?
take care
Don
1999 F150 4x4 4.6V8 regcab/shortbed
Oxford White with Wedgewood Blue two tone, with Blue Captains chairs
Bullet Cat Back, Superchip, K&N FIPK Intake.
Centerline Saber rims 17x8" with Firestone GTA 275/60hr-17 tires.
Alpine CDA-7845, ADS P640 Amp, Focal Poly Kevlar seperates.
http://members.tripod.com/donf150/Welcome/id7.html
[This message has been edited by Don C (edited 11-27-2000).]
Old Nov 28, 2000 | 07:35 PM
red97's Avatar
Post
no, it is still a sealed enclosure. Diamond Audio calls for a .5 cuft enclosure. That measurement includes the displacement of the sub itself (magnet, subwoofer basket, etc...) so what I did is took .5 cuft and subtracted the displacement of the sub, which is .128 and came up with .372. So when you mount the sub upside down you have to reverse the polarity(+/- and -/+) and include the area that is in the bowl of the sub cone and the area of the hole you cut out in the side of the box. In other words the cuft measurment inside the box itself is not .372. You come up with .372 by adding the box interior(lxwxh) to the mounting hole(area of circle x thickness of the wood(3/4") to the area inside the bowl of the woofer cone, because in it's resting state it is part of the volume of the enclosure. To make it simple, it's a sealed enclosure.
An infinate baffle enclosure is one that is used in cars with trunks and the sub is mounted on the rear deck and uses the entire trunk as it's enclosure. That type of enclosure can't be used in a truck.
Sorry about all the techno garbage.
Old Nov 28, 2000 | 07:41 PM
red97's Avatar
Post
P.S. And the subs do sound awesome.They thump very hard and also hit the lowest notes that you can't hear but only feel very well also. One thing that helped me out was that Diamond Audio calls for a very small enclosure. Most companies ask for bigger enclosures. I would suggest these subs to anyone. They are pricey though. $250-$300 per sub.
Old Nov 29, 2000 | 12:48 AM
Jupiterak's Avatar
Thumbs up
Very nice job. That's how I would have done it, but I have the 60/40 seats. I had to do alot of cutting to get the two decks to fit mine.
1999 F250 LD S/C XLT 4x4
5.4L, 3.73, 4R100 trans.
Flowmaster 40 "DF" series, K&N, Superchip, WMS Velocity Tube, Rancho RSX shocks, Hellwig rear swaybar, Stull billet grille, 2-PIAA Pro80XT's (120W), 2-KC Daylighters (150W), Clear Side Lens Mod w/ 9006 (55W bulbs). 265/70 R17 BFG AT KO's on 17x8 American Racing Atlas rims
Kenwood 7007 CD, Alpine 3342 Signal Processor, Alpine MRV-F353 5Ch. Amp, Pioneer TS-A6865 3-way speakers, MTX Thunderforms. CompuStar alarm/autostart. On the way: Performance Accessories 3" body lift, 33/12.5/17 ProComps, GSP grille guard and more KC's
Old Nov 30, 2000 | 03:07 PM
red97's Avatar
Post
With my EQ I could have done it that way without cutting anything. My EQ in the dash is only the face plate. The brain mounts in another area and allows you to mount the face in a shallow area. In my other truck I had it mounted in my headliner between the visors. I may mount it that way in this truck too. I want to get the factory top plate for my expy console where my A/C controls. The factory mounted A/C controls there at one point.But it runs $100.
