Speaker/Amp Help!
Old Apr 1, 2000 | 12:20 AM
kfarquhar's Avatar
Post Speaker/Amp Help!
I have a new 2001 Ford F-150 with premium sound. It sucks! However, I like the looks of the HU. I would like to know, do you think I could still use the head unit with a 70 x 2 RMS amp along with say Infinity Kappa components for the front or Memphis components. I am leaving the back speakers alone. I am looking for a good sound, no SQ competitions, just a good sound for my truck. Or would a good pair of Polk dx 7 3-ways powered by the amp be just as good a sound as the components. Also, would there be a problem with the built-in amp located in the Ford HU that would conflict with the added amp? I would appreciate the insight.
Thanks!
P. S. Great web page you got there!
[This message has been edited by kfarquhar (edited 03-31-2000).]
Old Apr 1, 2000 | 12:30 AM
TAZMAN's Avatar
Talking
Hello-
I have hooked an amp up to mine and there is no problem. the only problem you will run into is that the factory unit does not have pre amp outputs so you will have to get a converter for this, they run between 10 and 20 dollars and are very easy to install, other than that there no reason you cn't use an amp. Hope this helps.
2000 F-150 Supercab
Toreado Red
4.2l V6
Flowmaster 40 series single in dual out
K&N aif filter
Class III reciever Hitch
Mobil1 Synthetic
tazman_65@hotmail.com Home
norman.green@equistarchem.com work
[This message has been edited by TAZMAN (edited 03-31-2000).]
Old Apr 3, 2000 | 09:46 AM
Tina's Avatar
Thumbs up
I too have left the "premium" Ford head unit and added speakers and a 5-channel amp. And like Taz said, you will need the line output converters added. I know the head unit has an amp on it but it's not very powerful. I've added Memphis components up front and 5x7's in the rear along w/a 10"sub. My last truck I had 4 Polk 5x7's. Both trucks sound great but the components do sound better than the 5x7's. Your choice will depend on your ear and budget.
2000 F250 Crew Cab 4x2 6 speed Diesel XLT Super Duty, Woodland Green
Power Mirrors, 3.73 LS, Captains Chairs, ARE tonneau top, mud flaps
Trailer tow Pkg, Class IV hitch, sliding rear window, running boards
rear privacy glass, 265/75/16 AS OWL tires, am/fm/cassette/cd
Clarion APA 5240 amp, Memphis speakers:Components front, 5x7 rear, 10"sub
SuperChip, Stepshields, Ventshields on windows, rubber bed mat
rugged liner bedliner on tailgate
unaFORDable (decal on tailgate)
Old Apr 3, 2000 | 02:00 PM
kfarquhar's Avatar
Post
Thanks for the info. Tina, what size components do you have in the front, 5.25? Where can you buy and hear those Memphis speakers? I keep hearing about them.
So you can definately tell the difference between components/amp and coax's/amp.
Do you think a low priced component and amp is as good as a high priced 2-way/3-way coax and amp?
Old Apr 7, 2000 | 02:33 PM
TekSec's Avatar
Red face
Here is the link to the Memphis site. Hope this helps...
http://www.memcaraudio.com
2000 F-150 XLT, Deep Wedgewood Blue/Silver,4.6L,3.55LS,Class III Tow, Keyless w/alarm, soft tonneau. Basically a Lariat w/o the Leather!
Mods:
Line-X Spray Bedliner,Clear Corners and Tails,Airaid Intake, Superchip (Whatta RUSH!), Borla Anniversary Edition CatBack,
Future Mods:
3 1/2" Lift (Fabtech)
Eaton Supercharger
Roll Pan w/ Hidden Hitch
teksec01@hotmail.com
Old Apr 7, 2000 | 07:30 PM
linedog's Avatar
Post
kfarquhar,
I just installed the polk aoido dx3065 componet system (witch is 6.5")in the front door's of my f-150,no cutting was nessary.I would recomand a comp sys over the dx7's..although the dx7's are awsome, with our trucks you need the tweeter out side the door panel to get the highs we all want.If you go with componets you will need to make a plate,I made mine out good quality of 1/4" plywood,this 1/4" will allow 6.5"with no cutting of door,instead of 5.25"witch you would have to make a plate for anyway,hope this helps if you have any questions e-mail me at (linedog@home.com).....see ya and good luck
[This message has been edited by linedog (edited 04-07-2000).]
