Good cb and antenna?
Im thinking of getting this cb and antenna
cb-
http://www.walcottcb.com/midland-100...dio-p-735.html
id get it with the lighter plug soldered on
antenna
http://www.walcottcb.com/k30-magnet-...nna-p-769.html
this site has some non magnet antennas too but i cant find a bracket to attach it to my toolbox(where id put the magnetic one)
thoughts,comments? id use it for back country wheeling and roadtrips, with the possibility of a pa speaker later.
cb-
antenna
ok so the items listed above are on their way. i think im going to put the antenna on the toolbox. where do i get a cheap srw meter so i can make sure its good. ive heard talk of below 3 or 2. does that mean the ratio of channel 1 to channel 40 is 3:1?
Originally Posted by referee54
Would mounting the antenna on the toolbox affect your reception/trnasmission toward the front of the trucK? Just wondering...
Tim C.
Tim C.
While I didn't really want to do it, my magnetic mount is on my roof. I figure if there are little scratches, at least nobody is going to see it up there. great reception with a well-tuned antenna.
Same here. I have a little mini-3' mag-mounted anntenna that I stick on my roof when I need it. It makes my truck look gay up there so I'm triyng to find a place to put it permanently so it dosen't look gay but in the meantime don't want to be a big redneck 10' pole sticking into the stratosphere, either
Originally Posted by Big Lou
Cut out a piece of wax paper ( stuff used in the kitchen ) and place it between the mag mount and the truck. It won't affect performance and wont scratch your paint.
Tim C.
For those of you who dont want to mount on roof you can always mount off to side of bed. I have a stake hole mount mounted to side of bed rail with a
3' wilson fiberglass antenna with spring and it looks good and the reception is pretty good as well. When I had SWR checked the tech said my numbers couldnt get any better.
just got my cb and antenna. it wont mount to the toolbox either cause of the truck bed coating or cause its aluminum. but it still looks ok on the roof. now i just gotta real the manual and go out on the highway to listen to people.
got everything mounted up and set up.
i have more pictures of how i mounted it using velcro and of the antenna. everything works great, now i just need to get out on the highway where i can use it
I used the same type of set up---a DC plug and heavy-duty velcro. I also just ran the antenna lead under the front seat and ouot of the back door. That way if I need to bring it into the cab it is a snap.
TSC
TSC
