Please Help with CB PA System
Old Dec 29, 2007 | 04:43 PM
Skrewd's Avatar
Hey guys, I have my Cobra 19 all setup. I bought this PA Speaker so I could take advantage of the PA feature on my Radio. Tell me If I got this right, I took the two wires coming off the Speaker and wired them to a 3.5 mm Jack, and plugged it into the PA output...this is all I have to do right??? Well, its not working, but the weird thing is, I plugged into my Blackberry, and it will play music from that...so I'm stumped!!
Old Dec 29, 2007 | 06:01 PM
CRF250rider1000's Avatar
Are you getting power to your cb radio? Do you have the volume down and your mic gain up? Are you sure you have power to the PA jack when you engage it?
Old Dec 29, 2007 | 06:54 PM
2006M50B's Avatar
I am gonna ask the stupid obvious question-did you have the cb set to PA?
Make sure cb is on
make sure set to PA
if it doesnt work then there is a wiring issue-is the plug you used the one the manual for the cb says it uses(plug may fit but may still be wrong-has to be the right plug)-also does the polarity on the plug matter to match the speaker, you may have the + and - mixed up
if the above doesnt work then recheck your wiring from the cb to the speaker-loose connection maybe?
Old Dec 29, 2007 | 08:08 PM
MmmBuckles's Avatar
if the wires are touching it wont work
Old Dec 30, 2007 | 02:24 PM
IDNC76's Avatar
might be to powerful of a speaker, my old cb pa speaker was only 12 or 15 watts i think
Old Jan 12, 2008 | 09:48 PM
Raptor05121's Avatar
Running the RadioShack 50W fine. Like MmmBuckles said, make sure the wires arent touching. Try switching the wires, you might have + and - mixed up.
Old Jan 24, 2008 | 09:27 PM
STXDriver's Avatar
You need an amplified microphone to make the PA system work properly.
Old Jan 24, 2008 | 10:01 PM
Radio's Avatar
Sorry, but you do NOT need a power mic, the stock mic will work fine. I used an Astatic 636L noise cancelling mic and it works fine... but a Cobra 19 is the lowest on the totem.
Old Jan 26, 2008 | 07:39 AM
STXDriver's Avatar
Let me rephrase my statement. You need an amplified microphone in order for the PA system to be loud as it's designed to work.
Old Jan 29, 2008 | 11:28 PM
Yesh. Mine works fine though. I had my cab loaded with friends and we got into an argument with a little red Ford Ranger across the parking lot at Publix. For like 20 mins people were walking to/from their vehicles hearing two guys swearing and threatening eachother over loudspeakers!
Also, later on we got stuck behind s bus full of Mexicans so we continued to play "La Bamba" over the PA. Little did we expect, they all started dancing!!!
Old Jan 29, 2008 | 11:41 PM
army1's Avatar
where did you mount your speaker, do you
have pic?
Old Feb 2, 2008 | 11:31 PM
I put mine on the drivers side under the front grille pointing into the lower valnce. I mounted the base onto the frame and to do this I had to remove that lower rubber air duct Ford had plastic-riveted on the bumper
Old Feb 3, 2008 | 12:54 AM
army1's Avatar
thanks
Old Feb 4, 2008 | 12:03 AM
madmaxwell87's Avatar
how many watts in a speaker do i need? i just bought this cb http://www.walcottcb.com/midland-100...dio-p-735.html
and this antenna
http://www.walcottcb.com/k30-magnet-...nna-p-769.html
im looking to possibly put a pa speaker in latter and i was looking at speakers. they go from like 5 to 20 watts but i see you guys talking about 50w ones. so how many watts do you think i would need/want?
Old Feb 5, 2008 | 12:52 AM
army1's Avatar
this is the one i bought at radioshack, 35.00
100-Watt PA Indoor/OutdoorPowerhorn
they carry then in store but you can see
it online
