Mobile Ham Radio Were to Install
KD4CRS
Yep, that is the best way to do it. Everything you said is perfect.
Not to many folks are willing to 'cut' a hole in vehicle sheet metal. I used a 3/4 inch chassis (radio chassis) punch to 'cut' my hole.
Good pictures also. Good lookin SCrew.
N8PDQ
WV
N8PDQ
WV
Antennas
Antennas should be made of a metal product. Fiberglass sheath is O.K.
VHF antennas should be 'cut' to the proper length, for amateur radio 144-148 MHz band, there are antennas as short as 17 inches up to 39 inches.
Ensure that the VHF antennas are of proper wave length AND they are at least 1 wave length apart. More than 1 wave length is better.
I am assuming that the two antennas that you speak of are for different radios and not be used as a phased vertical pair antenna.
I know that some like the look of symentry in antennas. One is an active antenna, the second is just a fake antenna. Looks good though but still be sure of the distance between the antennas.
RR
RR
