9 Conductor Speaker Wire Question
I'm currently looking for manufacturers and sources for multi-conductor speaker cable in order to eliminate running multiple strands of wire in a limited space.
So far, I have seen that Streetwires sells 9 conductor SmartWire in 18 gauge, and Monster Cable also offers the XLN OEM speaker cable 9 conductor in 16 gauge.
Are there any additional manufacturers of 9+ conductor wiring that can be used to interface with OEM speaker wiring and as a remote amp turn-on lead? Does anyone offer this multi-conductor wire in any gauges larger than 16?
This wire will be run to a set of components and a set of coaxials from a 100x4 chan amp (USAMPS XT-1600.4). Would 16AWG be sufficient, or do I need to go with larger diameter wire?
Any leads for good sources of obtaining the wire would also be appreciated.
Thanks!
Thanks!
