IDEAS?/help
Old Jan 15, 2007 | 09:37 PM
rstacky's Avatar
IDEAS?/help
i am a 17yrs working on my frist truck it is a 94 f-150 5spd 300-6 and it is black w/ red strips i have a JVC Head unit, plye blue label speakers all around, and two pyramid 8" 400 watts subs on a 200 watt amp looking for a 800 for this, and rear speakers are on a alpine 2/3/4 chanel MPR-240 Amp. does anyone have some opinions/Ideas for upgradeds? ideas for the 800watt two chanel amp for the subs? tell me what u Think?? THANKS
Old Jan 15, 2007 | 10:45 PM
Bartak1's Avatar
Well first off, that 400 watt rating on the subs are probably the MAX rating, which really means absolutly nothing. You need to look at the RMS rating. Im guessing its somewhere around 100-200 watts rms per sub. Once you have that, you need to find an amp that has a matching RMS rating. So, lets say those subs are 200watts rms a piece, you would need a 400watt rms amp. Do you know what ohm your subs are? Also, dual voice coil of single voice coil? If the subs came together in a box, it probably says what ohm they are wired for on the terminal cup. I would assume they are 4 ohm if they came that way...If you bought them separtate out of a box it could be anything, we need that info.
With that Alpine amp, I would run a speaker off each channel. Or, if the front speakers can handle the power, run the fronts brigded off the alpine.
How much are you wanting to spend on the sub amp?
Old Jan 16, 2007 | 07:04 AM
rstacky's Avatar
i think they are 200watts rms and 4 ohms thanks
