Pull 12 volts from 2007 XL
I need to install my Ham Radio back into my new Truck 2007 F-150 XL
where is the best place to pull the power from. I can pull it directly
from the battery. But before I do that I wanted to get some other
ideas. The radio will draw up to 15 amps when transmitting.
On my 97 F-150 there was a main distribution unit on the firewall
but I dont see one on this truck. I do see what looks like
a metal box with some large connectors coming out which
is attached to the firewall.
Rob
Rob
The distribution blocks can produce alot of noise and hash in your radio. The battery acts as a capacitor and "filters" the power if you will. Most times it will eliminate ingnition noise by using the battery as your power source. Personally I would use good quality 10AWG wire for the power leads. 12AWG at minimum.
