Need CB help...
Old Jan 17, 2006 | 06:32 PM
98Lariet4x4's Avatar
Need CB help...
I have a Uniden PC68 LTW that worked great in my Ranger. I took it out when I sold that truck and just got around to installing it in my F-150. Now it seems that I can't recieve, and when I transmit, the needle pegs all the way right. I never had a problem picking up truckers (I live about 3 mile from the interstate) before, so now I'm wondering what's wrong. Any help would be appreciated.
BTW, I have a 5 ft Firestick for an antenna. If you've seen the pics, the other one isn't hooked up, just there for looks.
Old Jan 18, 2006 | 04:12 PM
ncpwt's Avatar
Well, since it's a new truck, it's basically a new install, which means the antenna needs to be retuned. VSWR can be a tricky beast. I'd pick up a cheap vswr meter and tune the antenna. ( or worst case, take it to a local shop and have them check your power out and vswr.) This shouldn't cost you over $10. Plus it'll give you peace of mind knowing it's good to go. Hope this helps. -Chris
Old Jan 18, 2006 | 04:34 PM
I knew I should probably get the SWR's tuned, but I figured since I did not change anything, not the antenna or power cables, it wouldn't change. Guess I'll have that checked out. Thanks for the input, bro.
Old Jan 19, 2006 | 04:20 PM
minimustangs's Avatar
Re:
The other thing you might want to check (that is after you do your SWR ) is the antenna ground and the lead in from the antenna. Bad ground can throw SWR way off. Corrosion can cause problems; breaks in the insulation can let in moisture and short you 'stick out...and other bad things.
