Bluetooth Audio Installation Kit
Old May 26, 2006 | 12:56 PM
  #31
wauger's Avatar
OK so I got the prep harness the other day and am planning on installing it today or tomorrow. I will try to take pictures for everyone to share also. Can you guys verify the correct wiring scheme for me?
Yellow (IHF/Mute) --> Violet (Prep Harness/Mute)
Orange (IHF/Audio+) --> Black (Prep Harness/Audio+)
Blue (IHF/Audio-) --> Red (Prep Harness/Audio-)
Red (IHF/VBATT) --> Red/Yellow (Prep Harness/Run-Acc)
Black (IHF/Ground) --> Black/Green (Prep Harness/Ground)
Green (IHF/Ignition) --> Green/Yellow (Stock Harness/Ignition)
The only part I am confused about is the power. Does the VBATT wire from the IHF go to the RUN/ACC wire from the prep harness? Or is it the Ignition wire from the IHF go to the Ignition wire on the stock harness?
Please help me - I'm Confusled!
Old May 26, 2006 | 03:15 PM
  #32
wauger's Avatar
OK all. Well I hooked up the IHF using the prep harness today and something isnt right.
I was a little confused as to the power connections (above post) so I tried a few things which I thought would work.
1. Spliced all of the appropriate connections (above post)
2. Connected the IHF VBATT (red) and Ignition (green) to the prep harness RUN/ACC (red/yellow) wires.
That seem to switch the IHF on/off based on the ignition switch. The unit now in fact powers on with the ignition and the radio displays "phone" when the unit is invoked. However I hear NO audio out of the speakers.
I am going to check my connections again. Just thought I would post a play-by-play. Any help is appreciated. Thanks
Old May 26, 2006 | 04:23 PM
  #33
wauger's Avatar
Back again. So I think the power connections are alright. The problem seems to be the audio. For some reason the in-line audio connections arent correct, or something serious is wrong. When I connect the external speaker the system is audible just fine. When I disconnect the external speaker and use the stereo system I cannot hear anything.
After I memorized the voice commands I connected the stereo speakers and told the system to EXIT (even though I could not hear the voice prompts over the speakers). The systems exited just like I said. This tells me that the system is hooked up properly but for some reason the stereo speakers are not working...
Any thoughts?
Old May 27, 2006 | 01:45 AM
  #34
wauger's Avatar
Well it seems that all my previous posts were in vain. After more thoughtful troubleshooting I was able to solve my issue. The smaller molex connector (12-pin) in the head unit was not properly secured. A quick tighten solved the problem and now my system is working just fine. I did a few quick tests and am very pleased with the sound quality. There does seem to be one remaining issue though. For some reason every time I turn on the car and power up the IHF1000 the system will not automatically pair/connect to the phone. Even though I previously paired the phone and the system. I have to go into the phone's bluetooth configuration, delete the paired device, and repair them in order to establish a correct connection. This very well might be normal functionality of the phone I am using (Motorola MPx220).
I will keep everyone informed as time progresses. Thanks again to all for your invaluable help.
