Deus/Dupuis - Amp & Distribution Block Question
Old Mar 24, 2005 | 04:24 PM
97xltv8's Avatar
Question Deus/Dupuis - Amp & Distribution Block Question
Guys,
I did a little search on this topic but could not find anything I was looking for.
First question:
Can I mount an amp on top of the transmission hump under the back seat? Is the passenger side under the back seat ok too?
Second question:
I will be running two MTX Thunder 4202 amps, one for the Kappas in the front doors, and another to push a Pioneer flat sub. I will have a 60 amp fuse on the power cable going right into a distribution block. The thing I need to know is do I have to fuse each (2) connection coming out of the block? The MTX's are rated at 30 amps apiece. I was planning on 4-guage power into the block, and then 8-guage power for each amp.
Thanks for any help you all have.
Old Mar 24, 2005 | 05:09 PM
Bartak1's Avatar
Yes, its fine to mount an amp there.
You dont HAVE to fuse each wire coming out of the dist. block, but I would just as an extra saftey precaution. Can never be to safe. 30A fuses on each 8 gauge wire. Might not even need a 60 on the 4 gauge either.
The 4 gauge into 8 gauge will be good
Old Mar 25, 2005 | 01:18 AM
97xltv8's Avatar
Thanks Bartak,
The amp I was gunning for in Ebay ended up with someone else.... so I will probably either try again with Ebay, or visit Crutchfield for a cheap MTX. Thanks though, and I think I will follow your advice. Appreciate it man.
Old Mar 26, 2005 | 02:19 PM
Bartak1's Avatar
No problem
Old Mar 28, 2005 | 01:07 AM
97xltv8's Avatar
Well I got my 2-channel MTX. I won the bidding today on Ebay. All I have to do now is order all of my Brown Bread along with the Pioneer sub and the install will begin. I ordered the wiring kit last week.
This will be a fun project.
Old Mar 28, 2005 | 03:39 PM
Bartak1's Avatar
Always is.
Good luck
Old Apr 5, 2005 | 03:51 AM
97xltv8's Avatar
Bartak,
What's up man? I got the MTX from FedEx today. I am going to order a box either this week or next week along with the Pioneer sub. I am also about to order some 8-guage fuse holders from Crutchfield.
Just wanted to drop you a thanks. All your advice is much appreciated, and I will do my best to post some pics of my first install. I hope the box from musicmoose is not too hard to put under the rear seat with their lift kit.
Old Apr 5, 2005 | 03:15 PM
Bartak1's Avatar
Glad to help.
Definatley get some pics.
