Radio stopped working-help
I have a 1997 F150 with a factory radio, cassette and 6 disc changer. Recently the left speakers stopped working, would work sometimes, then all of a sudden all of the speakers do not work now. I tune a station or play a cd and everything seems to be working but no sound. I checked all fuses that had anything to do with audio or radio and they are all good. Any ideas would be appreciated.
Your problem could be something as simple as a shorted speaker wire somewhere in the truck, or a bad Deck. There are tests to test speaker wiring if you are up for it, but I'm not gonna write a description if you arent up for it.
ps... 97's have a separate speaker harness on the deck "wink wink"
One of the tricks of the trade to test speaker wiring...
You need a 1.5volt battery, some wire, and some electricl tape.
attach a lead of wire to each terminal of the battery, tape it up good, strip the insulation off the ends.
______________________/ <--wires to use for testing (+)
XXXXX
XXXXX
XXXXX
XXXXX <-battery
XXXXX
XXXXX
XXXXX
XXXXX
XXXXX
XXXXX_________________/ (-)
Now, take your "tester" and start touching the contacts on the 8 wire speaker harness from the deck, you will hear a static sound when you find a pair. Find all four pairs if you can, if you hear nothing either you don't have the right combination -or-an open wire/bad speaker. Then when you know what wires go to what speaker, hook the (-) side of the battery to ground(any ground will work) and then touch the (battery +) to every speaker wire, if you get noise, then you have found your problem wire.
Most times it's a wire that gets pinched near the speaker itself, in the door boot, or near the deck area.
Hope my pic doesn't too screwed up when I submit this!
I don't remember the colors, or I'd include those as well...
XXXXX
XXXXX
XXXXX
XXXXX <-battery
XXXXX
XXXXX
XXXXX
XXXXX
XXXXX
