XM Commander Disappointment
First a little history:
The stock stereo in my 99, 00, 01, and 02 F-150 XLT SCab all sounded pretty good to me. I installed a pair of Alpine 5x7 2-way speakers in the front door of the 02 and it sounded better.
My dilema:
I purchased a 2004 F-150 XL Scab with the dual media stereo system and decided to use the $300 Best Buy gift card that the dealer gave me to upgrade the speakers and install XM Radio. I chose the XM Commander because it was small and it wired directly into the head unit (thinking this would give me better sound). I also bought four Pioneer 6x8 3-way speaker to replace the factory speakers (Best Buy doesn't have JACK for speaker selection). The radio and CD player sound better with the new speakers, but when I turn on the XM, it sounds dull with very poor sound quality. I also have to crank the volume to hear the XM. I was expecting something between FM radio and CD sound quality when I made this purchase. I have already changed the radio station to eliminate the hiss on XM, and I cranked the audio level up to 8, which is the highest setting. The antenna is mounted in front of the 3rd brake light, and everything was professionally installed.
My questions:
Is this as good as it gets?
Are my expectations too high?
Did I buy the wrong components?
Should I throw more $$ (amp?) at this in hopes of making it sound better?
Should I uninstall the Commander and discontinue the XM service to cut my losses?
Any advise would be appreciated.
My dilema:
My questions:
Re: XM Commander Disappointment
My dilema:
My questions:
My dilema:
My questions:
We all have to turn up the volume alittle compared to CD and FM. Not as much as you are saying. I have the same xm install and get great sq and plenty of volume from it. Now I do have my after market speakers amped though. Not saying that an amp will solve all the problems, but that is where I woud start. My XM has very close to CD sq from it. Hope this helps.
If you ARE using a modulator, this is your problem. They work "OK" on a bone stock system, but as soon as you start making upgrades the audio system from there, you will only magnify the weaknesses of a modulator. Wait for the "direct in" AUX adapter. SQ should be great then.
Matt
EDIT: In the meantime, go back to Best Buy, and tell them you want a better modulator. The SQ probably won't get much better, but you should be able to match your levels a lot better...
Matt
So there is hope!
I have been doing a little bit of research and found this thread about the same problems that I have been having.
http://www.xmfan.com/viewtopic.php?t=33577
Where should I look for this AUX input adapter (when it becomes available) and which FM modulator is better than the one that came with the XM Commander?
Thanks, leapfrog and Matt.
