More XM Questions
More XM Questions
When I bought my new F-150, the dealer gave me a $300 Best Buy gift card. I would like to install XM radio and new speakers, but I have a few concerns.
I have heard that the XM units that are hard wired to the head unit have much better sound than the ones that use a FM channel. I am also concerned with the fact that on many of my cross-country trips, I will be driving through several different radio signals which could interfere with the XM signal. I have looked at the SkyFi2 and XM Commander, but from what I understand, both of these units use FM channels. Is there a quality XM unit that will hard wire into the factory head unit?
at this time, the only way to use xm or sirius with the factory f150 stereo is with the FM modulator. there are a few companies that are working on auxillary (AUX) input adapters, but none have been released yet. so your options are to use the FM modulator until the AUX input adapter becomes available, or buy a new headunit with an AUX input (which most have).
The Commander is hard wired to the headunit through the FM antenna, thus when using the Commander, the FM antenna is basically "shut off", The skyfi2 can be wired in using a pie adapter. Go to xmfan.com Their forum rock's, I got my Skyfi 2 from them. The Moderator "Ryan" is the store owner also and he knows his stuff. If all else fails, go there and get your info and buy at Best Buy.
As to Sirius, I've tried them, but I found that they replayed the same play lists all day. To me it was like FM radio without the commercials. I personally prefer XM
