Caps.?
Can you explain why you think it should be under 18" long?
Right now I'm running 5.5' of 1/0 then very short leads of 4 out to the amps. All my grounds are under 12" with bolts holding them down to bare metal.
i would agree witht he above and say there must be somthing wrong with the install.
I run four type r 10's and a tottal of 2100 watts rms in my truck all running off two deep cycle batterys and the optional 130amp factory alt and i have 0 dimming of any kind. as for the 10awg wire thats just silly and i'm shocked they recommend that. i run 0awg to my block and the 4awg out to the amps. you should have NO problems with a your truck and only 300 watts.
as for the 18 inch ground rule. thats 100% correct and good practice. if anything you can go even shorter then that if possible.
the sorter the better.
