Speed sensitive volume control
Old Nov 30, 2003 | 10:38 PM
joegr's Avatar
I have the factory radio with the extra 20 pin connector. It supports speed sensitive volume control, but it is not wired in on my vehicle. I believe that the needed signal comes in on pin 9 of the 20 pin connector, but I am not sure which signal to connect. Does anyone have a wiring diagram that calls out the Ford signal name for pin 9? Or does anyone have the pin connected and could tell me the colors of the wire?
Thanks,
Joe
Old Dec 1, 2003 | 02:34 PM
leapfrog's Avatar
I sent a reply post about an hour ago and it never showed up ......I will make this one shorter ......try turning on the radio and holding the volume **** in about 3-4 seconds and this should do it I think. adjust sensitivity by turning volume **** after it shows speed sense or something like that......mine has it and I dont see any sensors anywhere so not sure where the pickup is
