would this be safe?
Old Sep 25, 2003 | 03:58 PM
neck4752's Avatar
would this be safe?
Could i mount a sub that has a 5.25 in mounting depth in a subbox.net box with a max depth of 5.5. Would this be too close, or has anyone done this. Im hoping that the sub will be a ED e10k.14
And I am going to power it with a Rockford power 551x amp, and hopefully hide this under a seat.That should work right?
thanks
Old Sep 26, 2003 | 03:44 PM
Florida-150's Avatar
From what I understand as long as you have a small gap for the speaker to cool and vent at the bottom you should be ok. I asked this to a person at a local audio shop and they said the same thing so I think you would be fine with the 1/4" gap. Though I am not a 100% sure I thought I would share what I was told.
Old Sep 26, 2003 | 07:28 PM
neck4752's Avatar
Thumbs up hey thanks for in info man
I need some advice you know. haha
anyway thanks.
anyone else know anything about this?
Old Sep 26, 2003 | 07:38 PM
jabaron's Avatar
I would not do it unless it was a side vented sub. I would use a mtx 8000 series sub. I have a screw and I have the same specs and it works great!
Old Sep 30, 2003 | 02:38 AM
cgorris's Avatar
That would be plenty of room for the voice coil vent. As long as the hole is not plugged it will function prefectly fine without any ill-affects. You only need to allow it to move air in and out, it serves zero purpose other than to help cool the voice coil.
