HU replacement question
Old Apr 17, 2003 | 04:06 PM
aadbrogers's Avatar
I am going to change my stock headunit for an Alpine. The only problem is that the stock HU whole is to big for the Alpine unit. Do I need to make brackets to hold it up or is there a kit I can buy that will solve my problem.
Old Apr 17, 2003 | 05:18 PM
trashguy's Avatar
u need a dash kit,15-20 dollars
walmart or any electronics store have them.
they have pocket above the radio.
Old Apr 17, 2003 | 05:37 PM
Invalid_access's Avatar
Here is metra dash kit you can get at circuit city for 15 dollars. [IMG][/IMG]
Old Apr 17, 2003 | 06:17 PM
KingRanchSC02's Avatar
this is the kit i got from crutchfield, 15 bucks i think:
Old Apr 17, 2003 | 08:21 PM
Rockpick's Avatar
Moderator &
You'll be able to find the kit at ANY car audio shop. Shouldn't be more than $20
Old Apr 18, 2003 | 09:49 AM
aadbrogers's Avatar
KingRanchSCO2 your Alpine head unit doesn't seem to fit the Crutchfield kit. I looked to be too big for it. Is that a picture flaw or is the bottom hole bowed in?
Old Apr 18, 2003 | 10:06 AM
you're right. the bottom hole is a little bowed in. but when i went out there to look at it, the bottom hole isnt supporting the head unit at all, there is another brace above it that is doing it. i'm going to contact crutchfield and have them send me a new one. thanks for pointing that out aadbrogers
Joe
Old Apr 18, 2003 | 04:11 PM
Rockpick's Avatar
Moderator &
The first kit that I got from Crutch was also slightly bowed.... gotta keep them honest.
RP
Old Apr 18, 2003 | 04:26 PM
skicrave's Avatar
Installing the kit with the pocket on top with prevent the stress that is causing it it bend. If you look at the other pictures in this thread the headunit is on the bottom and there are no gaps around it.
The headunit is too long to fit on the top, so it's hitting the dash support in the back (which is why it's a bit hard to get it so slide all the way in). That pushes the back down, which make the kit distort a bit.
Old Apr 18, 2003 | 06:42 PM
i cut that piece of plastic outta there. it serves no purpose. and the pocket isnt supporting the unit at all. rp, did you call and get a new kit from crutch?
Joe
