street scene mirrors
Old Sep 7, 2002 | 04:55 PM
schoolbus's Avatar
Question street scene mirrors
ok , i was cleaning out the basement and i found the mirrors i bought two years ago and forgot about.
my ? is has anyone installed these before? i have a XL so it has manual glass but i bought the power loom but the directions are for a ranger(huh) would these be the same? and i couldnt find the tool i needed to take the door panels off, so could someone give me a heads up on where to get one?
thanks
moose
Old Sep 7, 2002 | 06:05 PM
4X4PWR's Avatar
The door panels should "pop" off. I did not need a special tool to release the doors. It has black screws with a push in tab. You simply push these tabs in with a screw driver until they click. You can then pull the screws out and then pop the door panel off. I have not wired my windows for power.
Hope that helps a little.
Old Sep 7, 2002 | 09:02 PM
WLF's Avatar
WLF
You will need a Torx (spell?) wrench to get the handle off. Then the panel comes off like 4X4PWR says. Pull out the push attachers and then lift the door panel up to release it.
Good luck and have fun. Don't know about the mirrors.
Old Sep 9, 2002 | 09:44 AM
schoolbus's Avatar
Thumbs up thanks
thank you for the help i have to wait till this weekend to do it
thanks again
moose
Old Sep 9, 2002 | 06:58 PM
hmustang's Avatar
How did you forget about them mirrors seems like you would have wanted to put them on as soon as you had them.
Old Sep 10, 2002 | 09:50 PM
schoolbus's Avatar
i moved
they were delivered the week my parents sold the house when i was down L.B.I. and they were put in a container that was marked Ron,s stuff. i moved into my girlfriends house and my stuff stayed in the basement. when the water heater blew out, we cleaned out the basement and thats how i found them.
moose
Old Sep 14, 2002 | 09:49 PM
LeanNCut's Avatar
Removal of mirrors:
1. Remove door panel (as directed above)
2. Detach triangular mirror sail cover
2. Unscrew 3 retaining nuts using ratchet and socket
Reverse directions to install new mirrors.
