Auxillary switchs help 97-03 f150
Old Jan 11, 2011 | 05:58 PM
stugraham's Avatar
guys i need help, not sure where to put my auxillary switch panel, i bought a ton of round rocker switches small ones, the first one is grill and tool box amber strobes, the second will be front, and rear hidden LED strobes, 3rd is momentary rocker to change flash patterns in Hidden led's fourth is back rack strobes, 5 is back rack LED work lights, 6 is under bumper LED backup lights here are the switches i bought http://cgi.ebay.ca/ws/eBayISAPI.dll?...=STRK:MEWNX:IT let me know id love to hear and see your ideas!!! thanks
Old Jan 11, 2011 | 06:14 PM
russ10screw's Avatar
Here's where I mounted my switch. Only one switch but bigger than your round rockers. Do you have the pedal adjusters? If not, should be some decent room right there and then its right next to your factory light controls.
Old Jan 11, 2011 | 06:50 PM
Raptor05121's Avatar
I put mine on the left and right side of the trim piece that sits around the steering wheel base
Old Jan 11, 2011 | 07:16 PM
lokilightning's Avatar
Hit up a junkyard and get the lower trim piece with the sunglass/wallet pocket in it. Remove pocket, install flat plate for switches, mount lower trim back to dash with switches installed. The pocket is near your right knee, but sunk in enough so your knee won't interfere with switches. Makes for a clean install.
Here is a link to a guy who does these for us Lightning guys. Post 5 shows the entire panel installed. http://www.lightningrodder.com/forum...t=switch+panel
Old Jan 17, 2011 | 09:25 AM
stugraham's Avatar
ive got a 98 xlt stx and the cubby hole down there i dont think is that big, and i have not looked below the headlight switch i will definately check that out though, and nope no adjustable pedals
Old Jan 17, 2011 | 09:53 AM
Wow, that install is awesome. Very clean. I like the looks of that a lot! Doesn't hurt that its in a lightning either!
