HID help
Old Jan 9, 2011 | 08:43 PM
johnbaughman85's Avatar
HID help
my HID headlights are real bright when i first turn my truck on. then after a short while they will go dimmer. what could the problem be. any help would be greatly appreciated.
Old Jan 9, 2011 | 08:49 PM
ridinonmoto17s's Avatar
hids flash bright real fast then go dim and start heating up to maximum brightness. do they stay dim? it typically takes about 15 seconds for them to heat up and get bright.
Old Jan 9, 2011 | 09:07 PM
yeah they warm up and get bright. but then after they just flicker to dim and stay that way
Old Jan 9, 2011 | 09:48 PM
MRLSU2U's Avatar
what kind of hids do you have
Old Jan 9, 2011 | 09:51 PM
i got the bi xenon 6000k from xenonlink.com
Old Jan 9, 2011 | 10:40 PM
MI02SVT's Avatar
yeah i know what you mean mine do the same thing they go through the startup process and then they dim out just the slightest bit never thought anything of it there still bright i figure they get back to the normal brightness just takes some time so you dont notice it not like when they go dim
i dunno maybe i just have a junk kit
Old Jan 9, 2011 | 10:52 PM
i dont think mine get back brighter. i didnt think i bought a crappy kit. for 150 dollars it shouldnt do this
Old Jan 9, 2011 | 11:16 PM
ELVATO's Avatar
This is what mine have been doing for the past +2 years (minus the 8000k color).
http://www.youtube.com/watch?v=Y8K1B7dAFcI
That's how most kits I've seen work (with some kits warming up faster than others). If yours are dimming I'd think there is something wrong with them? Contact your seller and see what they have to say.
Old Jan 10, 2011 | 04:18 PM
T3audioNavi's Avatar
sometimes, you have to upgrade the fuse tothe headlights at least 5 more amps, i have 12k on the navigator 6k on the f-150 and 8k on the impala, i upgraded the fuse on all of them by 5amps, and they are bright as hell imo.. illl make videos later tonight..
Old Jan 10, 2011 | 08:38 PM
Fabian06SC's Avatar
The fuse to the ballast shouldnt matter. If its not blowing your current fuse then it obviously isnt wanting to pull more amperage.
Either your bulbs are going bad or the ballasts are not producing enough voltage after ignition to keep the bulbs fully lit. (sounds more like the latter)
Both problems related to your kit, i would contact the seller.
I had a ton of problems with my xenon-link kit. A year after i purchased it, of the four ballasts i got, only one works to this day and finally just did different branded bulbs. 4 ballasts and five bulbs from them (head and fog kit) and only two (one fog one headlight) bulbs still work and only ONE ballast still functions normally. Just my personal experience. See if you can get some money back and ditch the crap HID kits.
Look up retrofit projectors on this site and do it right.
Old Jan 10, 2011 | 09:06 PM
Raptor05121's Avatar
Bad kit.
Old Jan 12, 2011 | 02:36 PM
yeah i guess its just a crappy kit. im gonna do the retrofit when i get some money. its hard being a college kid.
Old Jan 13, 2011 | 11:47 AM
maybe try some hid capacitors, i put two on each and it solved my flickering problems
Old Jan 14, 2011 | 03:58 PM
where do i get those from?
Old Jan 15, 2011 | 12:26 AM
Ever try googling it?
