Help blown fuse!!!
Old Jul 31, 2010 | 05:48 PM
MRLSU2U's Avatar
Help blown fuse!!!
Alright I installed the push button start in my truck today. Everything was working perfect until i put the truck back together. I blew the ignition fuse and replaced the 20A ignition fuse with a useless 4x4 relay (2wd truck) 30A fuse i need to know if this will hurt anything?????????
Old Jul 31, 2010 | 06:04 PM
DarkShadowSTX's Avatar
You didn't unhook the battery during install or did something else blow the fuse? Find a replacement 20A fuse because having a 30A in there, if there ever is a reason for the ignition wires to get too hot, it will melt your wires. You don't ever want to have a higher amp fuse than recommended because it will take longer to blow and find the next weakest link, the wires.
Old Jul 31, 2010 | 06:10 PM
papajohn's Avatar
did this blow when you first went to test your new toy?? double check your wire runs to make sure you did not cross anything or pinch a wire when you were reassembling you dash.
Old Jul 31, 2010 | 06:20 PM
MRLSU2U's Avatar
Bingo! and alright i'll go outside and switch it back to a 20A thanks
Old Jul 31, 2010 | 06:24 PM
No problem man.
Take some pics while you're out there. This will be my little project for tomorrow. Thanks
