Aftermarket MAF sensor or not?
i've heard you don't really get all the hp you can out of your cold air intake unless you get an aftermarket MAF(Mass Air Flow) sensor is this true? also these things clame to increase airflow up to 45%... has anyone installed any of the aftermarket MAF and knowticed anything?
the only time you will ever need a larger maf is if your adding boost. The factory maf will flow all the air your engine can possibly suck...in the 04+ trucks the maf sensor itself will never need changing even with boost, the intake or maf HOUSING size is what controlls the speed of the air over the maf. The larger the housing the slower the air moves across the maf.
