Amp Research Power Step trouble
Hey guys,
My 06 FX4 Screw came with the amp steps already installed but now one side is not working. I am trying to diagnose the trouble and the amp website says its either a connection problem or a bad diode.
Now looking at their install instructions for the F150 it does not show any diodes being installed so I am not sure thats it.... So I started to look into connection issues. I pulled the rear sill plate and took a look at the wiring, which looks like it was done differently from the directions. Connections are crimped in, instead of using the posilocks and there are 4 short wires with small diodes installed.... All my door ajar lights work properly too.
Can anyone who has these pop that sill plate and post a picture of what the wiring should look like? This way I can compare. I have tuesday off so I want to spend some time working on this if possible.
Thanks for all your help in advance.
Remove the harness to the step motor not working. Check for power a the plug. The + and - alternates for the up down function. That would be my first move. Your 05 might not need the diodes as it was an issue with later models.
I will check the plug tomorrow with the test light. I assume you just touch the 2 hot wires and open the door to see if there is power right?
Its weird because one side works and the other doesnt...
Hopefully I will know more tomorrow.
Also whats the difference between the brains? Like I said the truck came with them so I am not sure how old it is...
Not sure what the problem was but it is now working.
I tested and found power to the step both openeing and closing the door so I talked to amp-research and they said I would need to order a new motor. After getting off the phone with them, I went outside to remove the existing motor (3 allen bolts) and once I did that, the step dropped down. I then opened the door with the motor off and found that it worked. Put it all back together and everything works fine now.
I am thinking that either something was caught in the linkage for the step or the gear was stuck somehow. I believe I read somewhere that if these feel resistance they will not deply so you cant get your hand caught in them or have them come down onto a rock etc...
Just as an FYI to the difference between the brains for these, the new brain is long and narrow where the old brain is more square and a little bulky, the old brain does require the diodes to be wired in. I had to have them email me the instructions as I couldn't find them on line anywhere.
