Cb antenna's?
i would recommend the firestik antennas in either the 3 ft for the 4ft versions with a good quality mount and cable
many people also run a high end cobra, uniden or if you have the money even a galaxy cb radio
here is a website where you can get just about everything you need for a decent price
http://www.walcottcb.com/
if you dont have any kind of topper or cover on your bed i would suggest go to that website i listed above and pick out any of the stake hole mounts and put them on ur bed
or if you have a tool box you can get the side/vertical mounts and put it on the toolbox
there is also a mount on the website that is just for the f150 that mounts on the drivers fender between the hood and fender and then mounts on there
my gfs dad also has a mag mount on the hood of his older chevy
hope that helps
hope that helps
I've used the K40, firestick, and solarcon ant. From my experience the firestick works very well. I would go with it or the solarcon. It is about the same as a firestick but the tip slides in and out instead of tightening or listening a screw.
well, i wanted the BEST antenna i could get, so i bought a 102" whip and mounted it to he back of my tool box. Not everybody's preference, but I LOVE the look of it. And it is said to be the best antenna you can get for a cb as far as range and what not
there is red monkey in fresno ca. go wilson if you go magnet and fire stix if you go mountable! have had both thay rock living in ca id go magnet mount so when not in use you can hide and get that cleen look pluse crooks cant tell you have a cb!
Maybe if it's amplified (?)... You can't tune an 8' whip itself like you can a K40, Firestik, ect.
I bought the whip. Love the look of it and I don't like the magnetic mounts that go on the roof. Bought my antenna at a local shop. Here's my truck with the whip.
http://i468.photobucket.com/albums/r...URTRUCK002.jpg
http://i468.photobucket.com/albums/r...URTRUCK005.jpg
http://i468.photobucket.com/albums/r...URTRUCK008.jpg
http://i468.photobucket.com/albums/r...URTRUCK004.jpg
Ehh... Not from my experience. I had one on my old truck. Didn't work that well and it started to look obnoxious to me... Makes trucks look like remote controlled toy cars.
[IMG]
[/IMG]
kind of like this, have had this setup for almost a year i love it. it's out of the way and i have it wired for dual use EMS scanner / cb
3ft firestick
if you want more pics let me know. will get you some of the bracket i made also if interested
[/IMG]kind of like this, have had this setup for almost a year i love it. it's out of the way and i have it wired for dual use EMS scanner / cb
3ft firestick
