Need Help W/ Train Horn Install
Old Dec 24, 2007 | 05:04 PM
zhoova928's Avatar
im in the middle of wiring up some new train horns and i have to wire it to an "accessory" so the compressor will turn on when i turn the key. what do i plug this to??
thanks
Old Dec 25, 2007 | 08:24 AM
NoLongerJeepin's Avatar
any 12v sorce that is switched on when the ignition is. i know in the 2005 the cigarette lighter will work. or the radio. you could even just wire it to a switch then hot wire it to the battery and just flip the switch to turn the compressor on. hope this helps!
Old Dec 25, 2007 | 05:47 PM
zhoova928's Avatar
alright man thanks
i figured it out and its finished
EFFIN AWESOME HORNS!
Old Dec 26, 2007 | 03:41 PM
IDNC76's Avatar
i did the same thing, wire to an acessory , but be careful, my battery died the other day because wen u go to start the truck, u usually put the acessorys on, well the compessor would turn on, and i could see my battery gauge depleteing, and it would srtuggle starting up, so right now i just took out the fuse for now , until i could install a flip switch or something of that nature. just fyi.
where did u get her, hornblasters? if so which 1, i got the conductors speacial, and it is amazeing.
Old Jan 3, 2008 | 08:19 PM
98 SNAKE EATER's Avatar
Originally Posted by zhoova928
alright man thanks
Did you at least use a relay for the compressor?
Old Jan 5, 2008 | 07:18 PM
Raptor05121's Avatar
Lets get some sound clips or videos!!!
Old Jan 8, 2008 | 09:57 PM
zhoova928's Avatar
i did use a relay and ill try to get some videos up soon but theres already pics in my gallery
