getting a toolbox
Old Dec 10, 2007 | 06:26 PM
madmaxwell87's Avatar
getting a toolbox
tommorow im going to go pick up a silver diamondplate aluminum toolbox for 75. i want it black so im going to sand it and cover it with duplicolor's truck bed coating. Its a above the rails type but i dont know how to mount it. i assume its just holes through the rail with two bolts with nuts per side? Any other ideas for making it black?(my other thought was just primer and flat black)
Old Dec 10, 2007 | 08:25 PM
TX-FX-4's Avatar
Line-X
Old Dec 10, 2007 | 09:00 PM
id love to but definately not on my budget..thats why i want to use the duplicolor stuff...same idea...10 bucks a can
Old Dec 10, 2007 | 09:06 PM
chevysucks9891's Avatar
if you do end up painting your toolbox black tell us how it looks id like to do the same thing to mine
Old Dec 10, 2007 | 09:18 PM
im getting it tommorow and probably wont get it painted until this weekend...but as soon as i do i will post up with results and pics...
Old Dec 11, 2007 | 10:23 AM
so how should i mount this thing? i found these http://www.buyautotruckaccessories.c...-mounting-kit/
but im not totaly sure how they work.
i think my other option is to just drill two holes through the box and rails and put a bolt,washer,and nut through it...am i missing anything?
Old Dec 11, 2007 | 12:45 PM
NoLongerJeepin's Avatar
no drilling a hole in the side of your truck is a horrible idea.
get 2 jay hooks (the bigger the better) and drop them into the mounting holes in the rear of the bed.
drill 2 holes, one on each side of the box. on the surface that sits on the bed rails. then feed the threaded end of the J hook through the hole that you drilled.
then bolt them down.
i apologize that this is such a horrible explination but its the best i could do.
bottom line DO NOT drill into the bed unless its a POS beater that you want to let rust.
Old Dec 11, 2007 | 12:49 PM
its definately not a beater truck...so you mean the bed stake holes at the front corner of the bed for the front? and j's 4 the back that hook under the lip of the bed?
Old Dec 11, 2007 | 12:51 PM
here i found an artical that should help you out.
http://www.diynetwork.com/diy/ab_par...271276,00.html
just make sure you have somthing in between the tool box and the bed so it doesnt scratch and you end up with rust
Old Dec 11, 2007 | 01:11 PM
that site was awesome. thats my exact truck down to the color..haha. now i understand how it all works. thanks for the help
Old Dec 11, 2007 | 01:22 PM
no problem, good luck with the install.
PM me if you run into any problems
Old Dec 11, 2007 | 11:25 PM
got the box tonight, its dark so no pics yet. its it pretty good shape but itll probably need a new weatherseal on the lib but thats it...so now i have to clean it out, get some new shorter j hooks and mount it up...then comes the sanding and painting when i get some time
Old Dec 12, 2007 | 08:40 PM
got the shorter j hooks and mounted it all up...spent the rest of the day sanding and priming...its about 1/3 done..its a pain in the butt to get between the little bumps of diamond plate...but even the primer sections look alot better...im going to keep sanding tommorow and hopefully ill be able to post up some pics of it all primered tommorow night.
Old Dec 12, 2007 | 09:37 PM
cool can't wait to see how it looks
Old Dec 12, 2007 | 09:42 PM
i got the real dark grey, almost black, primer to get an idea...pics tommorow when im done
