Choooo Choooo!!!!
Old Oct 30, 2007 | 07:15 AM
stuckiniraq's Avatar
Choooo Choooo!!!!
Train horn, on the truck im buying.........only thing is that if i ever do plan on doing any real offroading it will need to be removed first
Old Oct 30, 2007 | 11:04 AM
gixxer's Avatar
Nice. Where's the compressor located?
Old Oct 30, 2007 | 11:18 AM
In the bed of the truck............Ill try to get a picture of it as soon as i can, my buddy takes delivery of the truck this weekend for me
Old Nov 5, 2007 | 03:07 PM
mike8179's Avatar
chooooo choooo is right...that's some serious $*** What is that, 6?? I would love to here those things blow!!! I would agree about taking them off when off roading. good luck!!!
Old Nov 5, 2007 | 04:45 PM
clar's Avatar
Move the horns to inside of the valance below the radaitor then you dont see them or catch bugs and water with them.
Try not to scare some one off the raod accidently with those..............
Old Nov 5, 2007 | 07:20 PM
Hitched_Gibson's Avatar
Sweet. I should get my dad to put some on mine before I get home. That or the dixie horn.
Old Nov 5, 2007 | 08:15 PM
rsbeachbum2's Avatar
Once you got them you'll wonder how you ever lived without them.
Old Nov 6, 2007 | 12:30 AM
Right now its wired so that the normal horn button triggers the train horn. Im gonna have to rewire that so i can still use my regular horn. Cause the train horn is a little too much some times
Old Nov 6, 2007 | 10:24 AM
That's what I did. I ran it all to a switch. Up is train, down is factory and I still use the horn pad.
Old Nov 6, 2007 | 11:08 AM
Where did you get that switch at?
Old Nov 6, 2007 | 02:14 PM
It's just a simple rocker switch. Using 3 wide wire I tapped one of the wires into the positive wire on the factory horn and spliced the second wire in the group to the factory horn. The third wire went to the train horns. With all 3 wires in the cab I put them on the switch and you can toggle to which one you want.
The far left switch is the one for the horns.
Old Nov 7, 2007 | 12:37 AM
Nice, ill have to look into that
Old Nov 8, 2007 | 08:49 PM
98 SNAKE EATER's Avatar
Nice install, but those aren't train horns
Old Nov 9, 2007 | 12:25 AM
MmmBuckles's Avatar
then what would you call them?
Old Nov 9, 2007 | 12:27 AM
Justification Please????
