A remote start maintanence
Anyways, thaught I'd try remote start out the other day, no worky. Everything else works like lock/unlock (that and stop/start are the only other fcn's) but no start. Had this happen before, in the winter so I cleaned the battery posts and connections, and lubed with dielectric compound/ brake caliper grease from Motorcraft (ford). I also did inside the red plastic boot ion the starter and all the e-fans connections to the main controller. She works good now. It is a Polar start unit I got in late 99 for my 2000 f-150, thaught I'd share.
Tried the hood pin first, no dice. Even the wire that connected at one of the C.O.P's , 7 or 8 was leaning against the EGR (slight melt of wire), thaught that was it, nope. Finally did the terminals, ta da- works fine. Not to say the hood pin wasn't a good suggestion, especially due to position and abuse, but she's fine. I have put di-electric on it years ago when corrosion was starting and no probs since.
