Metra Axxess ASWC anyone familiar with...steering wheel control interface
Old Jan 19, 2013 | 06:34 PM
dixie_boysles's Avatar
Just hooked up a new Clarion CX501 double din on my 04 Lariat. Of course the steering wheel controls don't work now. I ordered a Metra Access ASWC steering wheel interface to correct that. Has anyone ever installed one here. Pretty easy?
Here is the kit:
Amazon Amazon
And here are the instructions for my truck. The only part I'm a little unsure of is number 4. Says connect pin 19 of vehicle harness to Ground....
http://db.tt/UDys6Tbz
Some help would be great
Old Jan 31, 2013 | 02:38 PM
oblivion's Avatar
Ground is the vehicales ground or NEGATIVE. wire into the main ground of the stereo harness or on a large bol/nut/screw thats into metal under the dash.
Old Feb 1, 2013 | 09:44 PM
kitchenboy's Avatar
Yeah not sure why they are having you ground pin 19 in the factory harness. I just installed a JVC and used the idatalink maestro sw to retain steering wheel controls. The nice thing about that unit is you program it onlie, and you can assine the steering wheel butons any way you want and can even add a couple things, so when you hold down a button it does another function. Like when I hold down my volume down button it mutes the radio.
Old Sep 19, 2013 | 09:41 AM
fine_style150's Avatar
Reviving old thread here- guys I need help in understanding, pin 18 and pin 19 can I do the connections from the harness side or from the truck side of cabling? First time radio install btw. Thanks
Old Sep 19, 2013 | 12:22 PM
bsn3971's Avatar
You can just do it from the harness side
Old Sep 19, 2013 | 05:35 PM
Great thanks!
Old Oct 21, 2013 | 09:02 AM
lakemarykid's Avatar
Bump on this thread.
From what I am reading the aftermarket harness does not come with anything in PIN 18 and 19. Do wires need to be added to these locations? Or should splices be made to the factory harness?
-Curtis-
