Hardwireing GPS
Old Oct 13, 2009 | 05:45 PM
larog72's Avatar
Hardwireing GPS
I am trying to Hard wire my Garmin Gps into my truck, I had it plugged into the rear power but my kids kept bumping into it and breaking the plug. I really didnt want it in the dash outlets only because I dont like the wiring hanging out. So I ran the wiring down through the dash and under the center conole where I ran the wires to the back of the rear power outlet (which is always hot). That worked fine but I am never satisfied and bordom kicks in and I decided that I would like it to run off a switch. So I now ran out, Got the switch and did what I thought was right but apparently isn't. there are 3 prongs on the back of the switch, One I know goes to the chasis ground, The other two I tried every which way I could and w/ no luck it is not working the Gps. So I am once again here on the forum hoping someone here has done this and could tell me exactly where to run these wires so I can turn the unit on and off by the switch. If you have a diagram it would be even better. Thanks. If you do have a diagram could you please leave me the link or email it to me at larog72@yahoo.com? Thanks Again..
Old Oct 14, 2009 | 02:03 AM
Sundevil2188's Avatar
You could always just tap switched power and avoid the need for the switch all together? Makes life a lot easier...
Old Oct 14, 2009 | 09:02 AM
hivoltagefx4's Avatar
I bought a hardwire plug for my NUVI 660 and tapped it into the radio power source. Looks clean. Comes on automatically when I start my truck and shuts off when I turn off the truck.
Old Oct 14, 2009 | 09:37 AM
thejake1989's Avatar
do you have the box the switch came in? is one of the prongs a different color than the others? post a pic of the prongs maybe
Old Oct 21, 2009 | 02:58 PM
SunDevil's Avatar
one is ground, one is 12V, and the other is the wire to the nav power.
